DZuck1
7 years agoIntel DisplayPort Arria 10 Sample Project Not Simulating Correctly in Aldec Active-HDL
Hi, I am trying to simulate the Intel DisplayPort Arria 10 Sample Project(Quartus Prime v17.0) in Aldec Active-HDL (v10.3 64 bit) and don't think the simulation is working correctly. The testbench...
BoonT_Intel
7 years agoHi Sir, do you have chance to try the simulation with latest version 18.1 or other simulator like modelsim?
By the way, Arria 10 DP do not have CDC or CRC setting.
- DZuck17 years ago
The only simulator I have access to is Aldec Active-HDL. The displayport core has a debug CRC setting that can be enabled to confirm the data received into the core. The sample design enables it by default. The User Guide shows that the CRC shouldn’t be 0. - DZuck17 years ago
I have tried to run this simulation using the pro version 18.1 and it still did not work correctly in Aldec. - DZuck17 years ago
Here is what Aldec prints out during the simulation: # KERNEL: start_main_link # KERNEL: start_test_main_link # KERNEL: Testing active line = 256 # KERNEL: Testing lane count = 4 # KERNEL: Testing Link HBR2 Rate (RX reconfig) # KERNEL: Testing Link HBR2 Rate (TX reconfig) # KERNEL: Testing maximum Vod and minimum pre-emphasis (TX analog reconfig) # KERNEL: Testing Link HBR2 Rate Training Pattern 1 # KERNEL: Testing Video Input Frame Number = 00 # KERNEL: Testing Link HBR2 Rate Training Pattern 2 # KERNEL: End Testing Link HBR2 Rate # KERNEL: Testing Link HBR Rate (RX reconfig) # KERNEL: TX Frequency Change Detected, Measured Frequency = 135 MHz # KERNEL: RX Frequency Change Detected, Measured Frequency = 135 MHz # KERNEL: Testing Link HBR Rate (TX reconfig) # KERNEL: Testing maximum Vod and minimum pre-emphasis (TX analog reconfig) # KERNEL: Testing Link HBR Rate Training Pattern 1 # KERNEL: Testing Video Input Frame Number = 01 # KERNEL: Testing Video Input Frame Number = 02 # KERNEL: Testing Link HBR Rate Training Pattern 2 # KERNEL: End Testing Link HBR Rate # KERNEL: Testing Link RBR Rate (RX reconfig) # KERNEL: TX Frequency Change Detected, Measured Frequency = 67 MHz # KERNEL: RX Frequency Change Detected, Measured Frequency = 67 MHz # KERNEL: Testing Video Input Frame Number = 03 # KERNEL: Testing Link RBR Rate (TX reconfig) # KERNEL: Testing minimum Vod and pre-emphasis (TX analog reconfig) # KERNEL: Testing Link RBR Rate Training Pattern 1 # KERNEL: Testing Video Input Frame Number = 04 # KERNEL: Testing Link RBR Rate Training Pattern 2 # KERNEL: End Testing Link RBR Rate # KERNEL: Testing Link HBR2 Rate (RX reconfig) # KERNEL: TX Frequency Change Detected, Measured Frequency = 40 MHz # KERNEL: RX Frequency Change Detected, Measured Frequency = 40 MHz # KERNEL: Testing Video Input Frame Number = 05 # KERNEL: Testing Link HBR2 Rate (TX reconfig) # KERNEL: Testing minimum Vod and pre-emphasis (TX analog reconfig) # KERNEL: Testing Link HBR2 Rate Training Pattern 1 # KERNEL: Testing Video Input Frame Number = 06 # KERNEL: Testing Link HBR2 Rate Training Pattern 3 # KERNEL: TX Frequency Change Detected, Measured Frequency = 135 MHz # KERNEL: RX Frequency Change Detected, Measured Frequency = 135 MHz # KERNEL: End Testing Link HBR2 Rate # KERNEL: Testing bpc = 1 # KERNEL: Testing Video Input Frame Number = 07 # KERNEL: SINK CRC_R = 0000, CRC_G = 0000, CRC_B = 0000, # KERNEL: SOURCE CRC_R = 0000, CRC_G = 0000, CRC_B = 0000, # KERNEL: Pass: Test Completed # RUNTIME: Info: RUNTIME_0070 a10_dp_harness.sv (1079): $stop called. Here is what is in the user guide: [https://www.intel.com/content/dam/altera-www/global/en_US/documentation/ufa1511788563556/ysy1475805841999.png]
