MuralikumarM
3 years agoIntel 40G Low latency IP RX PCS Ready status low
I am using intel 40G low latency IP core with Base KR4 and Optical versions. in Both a cases i am facing issues in getting PCS READY status as HIGH.
Nothing is available in the design and on...
ZiYing_Intel
3 years agoHi MK,
Since the compilation is ok and there are a lot of factors that may cause the rx_pcs_ready not stable. You may check back to your clock frequency to make sure that you follow the clock frequency that suggested in the UG. Besides that, it might be the wrong connection of the IP core also.
Please do check back your clock frequency and the port connection. Thanks.
Zi Ying
