MuralikumarM
3 years agoIntel 40G Low latency IP RX PCS Ready status low
I am using intel 40G low latency IP core with Base KR4 and Optical versions. in Both a cases i am facing issues in getting PCS READY status as HIGH.
Nothing is available in the design and on...
ZiYing_Intel
3 years agoHi MK,
You may refer to the compilation report. I suggest you to have a look on the warning inside the compilation report and then solve problem according the warning message generated.
Zi Ying
MuralikumarM
3 years agoZi Ying,
Most of the warnings are generated and shown inside the ip core only. what could be the method to remove these warnings..???
MK
