12 years agoInphase (I) and Quadrature (Q) components of signals
Hi All, How to calculate the Inphase (I) and Quadrature (Q) components of signals, such as RF signals? I would like to shift the RF signals to a specific baseband frequency and then derive the ...
11 years agoHi Lee,
--- Quote Start --- Thanks for the reply. I am trying to compile the testbench, automatically generated by NCO MegaCore function using Quartus 13.1 but an error message: "Error (10533): VHDL Wait Statement error at ncoIPDesign_tb.vhd(111): Wait Statement must contain condition clause with UNTIL keyword" --- Quote End --- I get a completely different error. Here's what I typed at the Modelsim prompt
cd {C:\temp\alteraforum-leeying}
vlib work
vmap work ./work
vcom -2008 ncoIPDesign.vhd
vcom -2008 ncoIPDesign_tb.vhd
vsim ncoIPDesign_tb
and that produced the following output # vsim ncoIPDesign_tb # Loading std.standard# Loading std.textio(body)# Loading ieee.std_logic_1164(body)# Loading ieee.std_logic_arith(body)# Loading ieee.std_logic_signed(body)# Loading work.ncoipdesign_tb(tb)# Loading work.ncoipdesign(syn)# ** Warning: (vsim-3473) Component instance "ncoIPDesign_st_inst : ncoIPDesign_st" is not bound.
This error is because the VHDL code you sent does not implement anything. Chances are that the files you posted are for synthesis only - note how the architecture of work.ncoipdesign(syn) is called syn. I would expect the IP to also generate a .vho file for simulation. You need to re-read the NCO handbook simulation section, it will typically give you instructions on how to simulate a design. Cheers, Dave
