AVija7
6 years agoIncorrect data at rx_dataout of stratix IV
Sir i designed the code for TX and RX using ALTGX,ALTRECONFIG in stratix IV. And successful at loopbacking, chip to chip communication.etc. In real case we have transmitter designed by someone else....
AVija7
6 years agoSir,
I was able to receive the proper data, but with reverse order.
Earlier problem solved by providing the correct values for LOCK TO DATA, LOCK TO REF inputs.
Problem facing now:
I wanted to receive BC95B5B5 but receiving B5B595BC.
This happened when i gave "Word aligner pattern : 17C (K28.5)---10 BIT"
When i gave BCBC (5F17C) as control code, i lost sync
not only that im not sure about the exact control code.
For 10 bit we cant enable byte ordering block.
How to proceed sir??
Thanks and regards.
