In Triple Speed Ethernet core, what does the COPPER_LINK_STATUS refer to?
Hi SK -
I believe I tried restarting auto-negotiation to no effect, but will need to confirm. If it helps, below are register dumps in the good and bad states for the PCS block (note that the addresses are byte addresses and not word addresses). I captured two different failures (rebooted in between and ran until failure again) - they seem to have differences that may be significant.
Also, the PHY we're using is a TI DP83867, if that makes any difference.
Thanks -
-Ryan
Good state:
0x00040a00 0x0000:1140
0x00040a04 0x0000:00a9
0x00040a08 0x0000:0000
0x00040a0c 0x0000:0000
0x00040a10 0x0000:41a0
0x00040a14 0x0000:d801
0x00040a18 0x0000:0003
0x00040a1c 0x0000:0000
0x00040a20 0x0000:0000
0x00040a24 0x0000:0000
0x00040a28 0x0000:0000
0x00040a2c 0x0000:0000
0x00040a30 0x0000:0000
0x00040a34 0x0000:0000
0x00040a38 0x0000:0000
0x00040a3c 0x0000:0000
0x00040a40 0x0000:0000
0x00040a44 0x0000:1101
0x00040a48 0x0000:0d40
0x00040a4c 0x0000:0003
0x00040a50 0x0000:0003
0x00040a54 0x0000:0000
0x00040a58 0x0000:0000
0x00040a5c 0x0000:0000
0x00040a60 0x0000:0000
0x00040a64 0x0000:0000
0x00040a68 0x0000:0000
0x00040a6c 0x0000:0000
0x00040a70 0x0000:0000
0x00040a74 0x0000:0000
0x00040a78 0x0000:0000
0x00040a7c 0x0000:0000
Bad state 1 ( Reg 0x5 = 0x0040)
0x00040a14 0x0000:0040
Bad state 2 (Reg 0x05 = 0xC2A0):
0x00040a14 0x0000:c2a0
