alinave
6 years agoIn the Low Latency 100G Ethernet Intel®Stratix® 10 FPGA IP Core, can one of the two ATX PLLs be used as a clock buffer?
The Low Latency 100G Ethernet Intel®Stratix® 10 FPGA IP Core user guide suggest that the input reference clock pin to the ATX PLL must be a dedicated reference clock pin (2.4.2. Adding the Transceive...
Deshi_Intel
6 years agoHI Naved,
Just want to close loop with you on this issue to set this case to closure since the ATX PLL usage model has been clarified.
For now, I am setting this case to closure.
dlim
