alinave
6 years agoIn the Low Latency 100G Ethernet Intel®Stratix® 10 FPGA IP Core, can one of the two ATX PLLs be used as a clock buffer?
The Low Latency 100G Ethernet Intel®Stratix® 10 FPGA IP Core user guide suggest that the input reference clock pin to the ATX PLL must be a dedicated reference clock pin (2.4.2. Adding the Transceive...
Deshi_Intel
6 years agoHI,
Yes, it can be used as clock buffer.
For reference, you can always generate the 100G example design directly from the IP core to review the design connection.
This is a better way to clarify issue rather than read through the doc.
dlim
- alinave6 years ago
Hi dlim,
Thanks for checking. It was not used as a buffer in the example design. Hence I wanted to confirm.
Naved
