OLevy1
7 years agoin the document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/archives/ug-altlvds-14.1.pdf, page 18
the configuration of 'What is the input data rate?' description is 'Specifies the data rate for the input channel of the receiver, in Mbps.' - my question is - i have 16 LVDS RX channels and the factor i am using is 4 (64b parallel bus). the data rate i need to use is for ONE Channel or for all 16 Channels together?
1 Reply
- SreekumarR_G_Intel
data rate is you specified in the IP for one channel .
Note : I answer to your post already ; but somehow it is not appearing in the community window ;
Thank you ,
Regards.
Sree
