ldm_as
7 years agoI'd like to try an Example Design for Avalon-MM Slave. Which one would you recommend to try with?
FawazJ_Altera
7 years agoHello,
You can export the custom component ports to the top level verilog file. Next, you can connect it to your verilog logic and test your design. Furthermore, you can add signaltap to trace the signals while running on board.
Unfortunately we dont have such a design.
