TFern4
7 years agoI2C (OpenCores) not working
Hi, I am using the I2C OpenCores v13.0 from https://fpgawiki.intel.com/wiki/I2C_(OpenCores) with the Platform Designer/Qsys and the Nios II Processor on the Quartus Prime, but it isn't working. I don...
FawazJ_Altera
7 years agoHello,
I am sending you a working design of Cyclone V soc using Opencores I2C. The I2C was used to read data from a sensor. I was able to see the sensor data output as expected without any issue.
Attached is the design.
Best Regards.
- TFern47 years ago
Do you know if using only the Nios II, without the HPS will it work? How did you make to run the C program with the I2C functions in Eclipse? I didn't find the .sopcinfo in your design . Thank you.
