I use the FPGA of cyclone V which type is 5CGXFC3B7F23C8N ,which has 1 GXB Bank (3 transceiver channel),CH0/CH1/CH2,but CH1 has error
Hi WQIUS,
Sorry for the delay. For your information, I have downloaded the cv_GX_1ch_40b_3125mbps.qar and tried to perform compilation in Q17.0 (since I do not have Q18.0 installed currently in my PC). After performing the auto-upgrade for IPs, removed all pin assignment as well as changing the parts to 5CGXFC3B7F23C8, I get into other Fitter errors which are different from yours. They are mainly related to unsupported PHY configuration and data rate. After fixing these errors, I am able to compile the design without Fitter error. Would you mind to share with me what are the changes that you have done to the cv_GX_1ch_40b_3125mbps.qar which would lead to your observation? This would be helpful for issue replication and further debugging.
Thank you.
Chee Pin
