AAbro1
6 years agoI have a basic question about Quartus tcl command "get_fanins". so I noticed that there are many options for this command and I'm confused which option should I use?
I'd like understand the difference between these 3 option: get_fanins -async get_fanins -sync get_fanins -clock because in the "get_fanin -help" I didn't understand the difference. is ther...
AAbro1
6 years agoThe definitions are not clear
-asynch Traverse through asynch edges
-clock Traverse through clock edges
-synch Traverse through synch edges
So for example I created this test case:
I get the fanins of the "In_pin" input using "-async" , "-sync" and "-clock" option and I get no difference between the 3 results.
So how can I see the difference between these options in a design?
