JHUAN157
7 years agoI got an error by using MegaWizard for generating Altera PLL vhdl code : Error: Execution of script C:/Users/JASONH~1/AppData/Local/Temp/alt8114_4660919192653077533.dir/0002_pll_gen/proj.tcl failed. What should I do about this error?
JonWay_altera
7 years agoHi @JHUAN157
Could you try it on a newer Quartus version, e.g. 18.1?
JHUAN157
7 years agoJW,
I am using Cyclone V GT FPGA Development Kit; not all the Quartus software support this device. For example, Quartus 18.1 does not support Cyclone V device.
Jason
- JonWay_altera7 years ago
Hi @JHUAN157
Are you referring to the Pro or Standard?
In the Standard Edition, 18.1 still supports Cyclone V.
http://fpgasoftware.intel.com/?edition=standard
- JHUAN1577 years ago
CW, I used Quartus Prime Standard Edition 18.1 to generate the PLL IP core successfully, but my design cannot be fit in the device. The error message says “Can’t fit design in device. Modify your design to reduce resources, or choose a larger device. …” My design can be fit in this device when I use Quartus II 13.1. Thanks, Jason
