ABhus
6 years agoI am using IOPLL Intel FPGA IP for Aria 10 SoC device. I need a clock of 307.2MHz/30.72MHz with a ref Clock of 10/100MHz . How can I get the exact clock?
With many possible combinations as well, I could get Actual output clock as 307.5M/307.142M/307.189M but not exact value. M,N,C Counter values can be edited only as integer values but not fractional ...
EngWei_O_Intel
6 years agoHi Anamika Bhushan
We can refer to the doc below (Section 3.1.3. fPLL) to check if we met the input reference clock spec for the fpll:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/ug_arria10_xcvr_phy.pdf
Fitter will prompt error when certain conditions are not met.
Eng Wei
EngWei_O_Intel
We do not receive any response from you to the previous reply that we have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
