URN
7 years agoHow to write/read to external DDR from custom Qsys component (custom IP).
I could write some data on to external DDR from HPS Linux C . I want my custom component to read that data from DDR , perform some operation and put the result back to DDR at different memory locati...
KennyT_altera
7 years agoHPS to DDR will have dedicated path for the interconnect in Qsys. You can try to use the custom component to access by sharing the master with the HPS. However, it might hit the fitter error since HPS to DDR have dedicated path.
What I would suggest is use your C code in HPS to control the address writing for the DDR.
URN
7 years agoOK Thank you.
