How to write/read to external DDR from custom Qsys component (custom IP).
A single slave can be accessed by multiple masters. You don't need dual slave ports, but your custom component does need a master interface (Avalon or AXI). Simply click the appropriate dots in the System Contents tab of Platform Designer, or right-click the slave interface of the DDR, go to the Connections submenu, and make the connections there. Check out this online training:
https://www.intel.com/content/www/us/en/programmable/support/training/course/oqsysfinish.html
#iwork4intel
- SVN7 years ago
hi, Thanks for the response,
A single slave can be accessed by multiple masters. You don't need dual slave ports, but your custom component does need a master interface (Avalon or AXI). You are right. I will check out the online training. Hope to find the solution soon...
Many Many Thanks
