How to write to EPCS memory without disrupting code execution for DE0-Nano board ?
Hi ThangND,
May I know do have the .sof file? In the case if you have the .sof file, you can Launch Quartus Prime software and open your project.
Go to the "Processing" menu and select "Convert Programming Files" option.
In the "Convert Programming Files" window, click on "Add" button to add the .sof file to the list of files to be converted.
In the "Output file format" section, select "Jam STAPL Indirect Configuration (.jic)" as the output file format.
Configure any other settings as needed, such as the location and name of the output .jic file.
Click on the "Generate" button to generate the .jic file.
The .jic file will be generated in the specified location, and you can use this file to program the EPCS memory on your DE0-Nano board using a programmer, such as a USB-Blaster or other compatible programming tool.
Fakhrul
