SCHAN189
6 years agohow to use serial flash loader ip with flash controller
hey, i'm facing problem with serial flash loader.I'm trying to use my own flash controller and the thing is i'm unable to access the flash memory. I'm currently using arria 10 fpga.I'm little confu...
NurAiman_M_Intel
6 years agoHi,
Can you please kindly check page 14 again,
from the AN370
data_in , data_out and data_oe are 4 bits
You are setting it to be 1 bits
i believe it is the RTL connection problem.
Try to check page 14 for correction connection with IP.
Thank you.
Aiman
