EEnam
7 years agoHow to use 4x10g phy as bare 40g phy without MAC ip
Hi, I successfully start a 10g PHY ip in way that i can receive the packet. Now I’ve been trying to configure 40g PHY without mac just to get any changes of data at IP output and I can’t achieve that...
Deshi_Intel
7 years agoHI,
So basically what you are saying is the XGMII_rx_data of 0x0100009C is the direct output from transceiver RX channel without additional data processing, right ?
I looked at the sim waveform btw 10G and 40G, the only obvious difference that I found is just on the xgmii_tx_control setting value. It's difference btw 10G and 40G.
Have you look at it ?
dlim
- EEnam7 years ago
Hi dlim.
Yes, you are right, “qsfp” signals in screen above is direct output from transceiver and rx-tx is looped in logic. I modify arrays names and control signals assignments for better clarity.
Only thing that is strange to me is that control signals is indicating data transfer (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/ug_arria10_xcvr_phy.pdf page 83, Table 60) when I think this is control word (http://www.ieee802.org/3/ak/public/jan03/WPcls48_1_0.pdf Table 48–2).
Apart from that, the control and data signals are just looped so it should work anyway.
