fxu001
7 years agoHow to solve error message for 17044 using device Arria 10: 10AX027H434i3SG in Quartus 18.1. It is urgent issue!
Hello, When I do analyze and elaboration step, Quartus 18.1 gives following error message as following as: Error (17044): Illegal connection on I/O input buffer primitive image_sampling:module_imag...
YuanLi_S_Intel
7 years agoHi Fred Xu,
This error indicates that the IP is not connecting correctly. May i know what IP you are using?
YL
- fxu0017 years ago
Hi YL, I think I found root cause. Basically Altera GPIO has two requirements: 1. It cannot drive two GPIO pins in the ddio mode. 2. it needs to directly drive from iBUF. The experiment and implement are both successful, and I am doing the integration with other modules which it should be okay now since I can use output to drive another fifo if I need. Please close this case. Thanks, -Fred - fxu0017 years ago
YL, Oh, it is GPIO. I will try to narrow down the problem. Thanks, -Fred
