fxu001
7 years agoHow to solve error message for 17044 using device Arria 10: 10AX027H434i3SG in Quartus 18.1. It is urgent issue!
Hello, When I do analyze and elaboration step, Quartus 18.1 gives following error message as following as: Error (17044): Illegal connection on I/O input buffer primitive image_sampling:module_imag...
YuanLi_S_Intel
7 years agoHi Fred,
I am glad that the issue has already solved. Any more help needed?
YL
fxu001
7 years agoHi YL,
Thank you so much for your quickly response. First I thought the problem solved, but later on the issue came out again. Would you think there is a setting to cause this issue? Could you image that any file that might cause this issue. From my understand from the EDA tool behavior, it seems some setting issue, but I don't which one should be suspected?
-Fred
