fxu001
6 years agoHow to solve (38): in protected region?
Hello, When I instantiation Altera IP alt_dual_boot.v, Questa simulation tool gives an error message as following as: # ** Error: C:/design/git_code/mbi-main-ctrl-fpga/fpga/ip/altera_ip/dual_confi...
RichardT_altera
6 years agoDo you have a test case that you can share? So to reproduce the error.
fxu001
6 years agoHello,
The issue gets solved. Basically what I did is using Arrie 10 device to generate script file from pull down menu "tool -> generate simulation script file for IP" to understand meaning of Questa requirements; then, generate Max 10 device the TCL script file.
Since sometimes new Questa user is not familiar with Questa tcl file requirements, it is a good approach to support tcl script file in any device in your late release.
Please close this case since I have a work around to bypass this issue.
-Fred
