zlan01
6 years agohow to simulate the altclkctrl IP ?
how to simulate the altclkctrl IP, which library should be included ? which file of the IP should be used ?
KennyT_altera
6 years agoPlatform design is a tools inside the quartus that use standart interconnect to connect your design. you can refer to https://www.youtube.com/watch?v=d43Pqc_IZpg
Yes, you can simulate the altclkctrl IP independent provided you know how to write the scripts. If you follow the https://www.youtube.com/watch?v=PmVVXQchv2c here, you will notice that the Quartus created a script automatically for you to do the simulation. You can make use of the scripts to do your altclkctrl IP independent of Quartus. -> msim_setup.tcl
