matif
7 years agoHow to setup Transceiver Phy Serial Loopback using C Application
Hi, In altera manual for transceiver custom phy ip, it is mentioned that it is possible to set up serial loopback by setting register equal to 1 at phy-mgmt_address 0x061. I have seen a tutorial a...
CheepinC_altera
7 years agoHi Muhammad,
As I understand it, you have some inquiries on way to enable the internal serial loopback for the XCVR custom PHY IP apart from using Transceiver Toolkit. One of the alternative way would be for you to perform the register writing by coding a state machine in Verilog to control the On/Off of the internal serial loopback. As I did a search in web, I found the following simple example design which might be helpful to you. It would be great if you could refer to it:
https://fpgawiki.intel.com/wiki/Arria_V_Transceiver_PHY_Basic_Design_Examples#Arria_V_Custom_PHY_simple_ways_to_enable_internal_serial_loopback_design_examples
Sorry as I am not familiar with C programming and thus could provide further comment on it. Sorry for the inconvenience.
Chee Pin
