how to run an example of Intel LL 10G MAC IP? I get similar errors in both examples. Please advice
Are you trying to use the Starter Edition of Modelsim or the payed version? There's a bug with the dev_com using Starter Edition in 18.0
- PVanL7 years ago
Hi AndyN,
Thanks, i am using the starter edition. ModelSim - Intel FPGA Edition vcom 10.6c Compiler 2017.07 Jul 26 2017.
i also submitted this issue on Forum.Intel, a little bit different, and looking again at transcript, i am not so sure if it is dev_com, see the snippet below.
vlog-13006) Could not find the package (avalon_mm_pkg). See line 32, 33 in Transcript Code generated by modelsim.
Where can i find this avalon_mm_pkg.sv code, and where should i put it?
i built a PHY for the cyclone10GX. I now want to connect the LL 10G MAC to it, and as test now trying to run the alt_em_10g32_EXAMPLE_DESIGN generated by QUARTUS version 18.0.0 build 219 04/24/2018 SJ Pro Edition with Cyclone10GX libraries. Modelsim version starter edition 10.6C, revision 2017.07.
I managed to get the msim_setup.tcl script running, until i face the following issue : when it compiles avalon_driver.sv, in line 66 it wants to import avalon_mm_pkg, but this file does not exist.
Modelsim reports (after compiling a lot of cyclone stuff) : see snippet, where in line 15 [exec] dev_com stops, and [exec] com starts
# Top level modules: # End time: 18:02:38 on Jun 25,2019, Elapsed time: 0:00:08 # Errors: 0, Warnings: 584 # Model Technology ModelSim - Intel FPGA Edition vlog 10.6c Compiler 2017.07 Jul 26 2017 # Start time: 18:02:38 on Jun 25,2019 # vlog -reportprogress 300 C:/intelfpga_pro/18.0/quartus/eda/sim_lib/cyclone10gx_hip_atoms.v -work cyclone10gx_hip_ver # -- Compiling module cyclone10gx_hssi_gen3_x8_pcie_hip # -- Compiling module twentynm_hssi_gen3_x8_pcie_hip # # Top level modules: # cyclone10gx_hssi_gen3_x8_pcie_hip # twentynm_hssi_gen3_x8_pcie_hip # End time: 18:02:38 on Jun 25,2019, Elapsed time: 0:00:00 # Errors: 0, Warnings: 0 # [exec] com # Model Technology ModelSim - Intel FPGA Edition vlog 10.6c Compiler 2017.07 Jul 26 2017 # Start time: 18:02:38 on Jun 25,2019 # vlog -reportprogress 300 -sv ../../../rtl/phy/altera_eth_10gbaser_phyaltera_xcvr_native_a10_180/sim/altera_xcvr_native_a10_functions_h.sv -work altera_common_sv_packages # -- Compiling package altera_xcvr_native_a10_functions_h # # Top level modules: # --none-- # End time: 18:02:38 on Jun 25,2019, Elapsed time: 0:00:00 # Errors: 0, Warnings: 0 # Model Technology ModelSim - Intel FPGA Edition vlog 10.6c Compiler 2017.07 Jul 26 2017 # Start time: 18:02:38 on Jun 25,2019 # vlog -reportprogress 300 -sv "+incdir+../models" ../models/tb_top.sv # -- Compiling package eth_register_map_params_pkg # -- Compiling package avalon_if_params_pkt # -- Compiling module avalon_bfm_wrapper # -- Importing package avalon_if_params_pkt # ** Error: ** while parsing file included at ../models/tb_top.sv(19) # ** at ../models/avalon_driver.sv(66): (vlog-13006) Could not find the package (avalon_mm_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line. # End time: 18:02:39 on Jun 25,2019, Elapsed time: 0:00:01 # Errors: 1, Warnings: 0 # ** Error: C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed. # Error in macro ./mentor.do line 25 # C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed. # while executing # "vlog -sv {+incdir+../models} "../models/tb_top.sv" " # ("eval" body line 1) # invoked from within # "eval $file" # ("foreach" body line 2) # invoked from within # "foreach file $design_files { # eval $file # }" # ("eval" body line 13) # invoked from within # "com"What is your advice? regards, Pieter
