How to map TX Avalon-MM slave interface into PC virtual memory?
- 6 years ago
Hi Eduardo,
No, the TXS port should connect to your application interface NOT BAR.
If the read/write request is initiated from your application via TXS port to the host, and then the host will be responding to those requests accordingly.
The size of the host system memory can be 32 bits (2 ^32) or maybe 64 bits (2^64), you will need to confirm it from your host system.
It depends on which locations of the system memory that you would like to read/write from FPGA. In the IP GUI, there is an address translator table for you to fill in, and this is up to the user to decide where the system memory that their design need to access.
Regards -SK
You have to map it to the host memory, and it depends where did you wanted to read/write from the system memory. This interface can access up to 4Gb of size.
Regards -SK
- EPino6 years ago
Ok, but that is the point of the original question. To map TXS to host memory i'll need a physicial memory address (that points to TXS base address), so that I can assign a virtual memory address to it, correct?
How can the host get that physical memory address? From the configuration space? Should I connect TXS to a BAR in Qsys?
Kind Regards,
Eduardo
