How to initialize the Configuration Space when PCIe core in Root port mode?
DHUAN26 - did you get any further? By the way - in one of your examples above remember that the register is shifted two bits in the config header, just a warning.
I'm trying to write the 0x18 register of the Arria-10 RootPort, with a value 00010100 - so the downstream bus would be 1, subordinate bus 1 (only one bus downstream). The write occurs to the RP on the Avalon bus, the RP responds with a status = success, but when I read that register I always get back 00s. Like DHUAN - I can read the dev-id (info configured in Platform Designer), I just can't write anything through the ST interface.
Anyone have success doing that?
I'm guessing I could move the config-space registers external, or use the LMI, but before that - this TLP method on the ST interface is supposed to work.
Bob
