basn
6 years agoHow to encode the data to higher frequency to transmit through fiber link and recover the data on receiver side?
Hi, I m trying to establish a fiber link between two FPGA board (MAX10M08) via a SFP-6 comnet fiber module. I'm using soft LVDS FPGA IP core for serialization and deserialization of the data. My da...
YuanLi_S_Intel
6 years agoHi Keshav,
Can you try with a LVDS IP instead of the "simply XOR the serialized data with the higher frequency ( above 500MHZ) before transmitting". If it is working, that means to say the method you are using may not be appropriate.
Thank You,
