corestar
Contributor
7 years agoHow to divide a clock by two without using a PLL?
I'm using the Altera Tri-Mode EMAC for 10/100 Ethernet with MII interface to the Phy. This uses 25 MHz tx_clk and rx_clk generated by the Phy and going to the EMAC. These clocks do NOT use dedicated ...
corestar
Contributor
7 years ago@sreekumar.regu.girijakumari , Using the enable is not a good solution. I'm forced to use a PLL for this purpose.
