How to convert combinational blocks to sequential blocks automatically?
I have a relatively large combinational block that is mapped to an Intel FPGA using Quartus Prime Pro.
I recently learned that an ALM can provide the output either directly from an adaptive LUT or from a register that latches the value of the LUT.
I was wondering if it is possible to automatically convert the blocks from combinational to sequential, which results in a deeply pipelined design.
- HBhat2
Contributor
In my view, one need to rewrite the RTL for sequential implementation. It is not possible to map combinational logic to sequential with the help of tool.
The Quartus tool maps the logics based on RTL code either to LUT or registers.
With Regards,
HPB
- sstrell
Without writing code to define the synchronous logic, there's no way the tool can automatically add registers into your design.
#iwork4intel
- KhaiChein_Y_Intel
Yes. You have to write the RTL to use synchronous logic.
