How to clock the Cyclone 10GX Transceiver Channel for 10GBASE-R
Thanks for your update. With the loopback test, it helps to narrow down to within the FPGA.
To further narrow down, I would recommend you to create a simple test design and perform Modelsim simulation to help isolating any functional issue. Please help to share with me this simple test design as well so that I could further understand your IP configuration and the connection.
Regarding the clocking, for the XGMII clocking, you would require 156.25MHz to feed the tx and rx_coreclkin. Just wonder if you have had a chance to try with that instead of feeding the div_clkout?
Chee Pin
- YYang795 years ago
Thank you, Chee Pin so much for your response.
I did try the clock of 156.25MHz to clock the xgmii interfase. It was a little bit worse than the pma_div_clock, which means i got more FE...FE words.
I have no idea how to simulate the transceiver with ModelSim. If you don't mind i can give you my archived design for your further investigation to it.
I am under huge time pressure now about this project and very looking forward to getting your helps .
Thanks again.
- CheepinC_altera5 years ago
For your information, I have created a simple simulation test design with Native PHY in 10GBaseR mode. In the simulation, I can observe fixed dummy data 64'h0707...07 at the RX parallel output through loopback. Note that this design is just to show the loopback data is similar to the data sent. I am not familiar with 10GBaseR protocol required data. Sorry for the inconvenience.
You may refer to the a.v and a_tb.v in the test_example\mentor folder for top level and test bench. You may ignore the other non-relevant codes in the test bench as this was taken from a different simulation example.
To run the simulation, do the following:
1. Unzip the folder
2. Change the current working directory of Modelsim to test_example\mentor
3. Type "source msim_setup.tcl"
4. Type "ld" to start compilation
5. Type "do wave.do" to populate the waveform
6. Type "run -all" to start the simulationPlease let me know if there is any concern. Thank you.
Thank you, Mr. Chee Pin. I will do.
Just FYI, and let you know what i have done to my design.
1)I have used xcvr Toolkit to test my designed hardware. When set serial loopback, It shows PMA stage is working well. It turns out zero BER. So it is definitely something wrong in TX-PCS stage. It cause missing word(64-bit) or FE...FE word.
2)When i use signaltap monitoring both transmitting and receiving sides they are stable in idle mode meaning i can see stable 0707...07 word. But, when i send out a packet, it sometimes not always, like a 10% chance it loses a word or give a FEFE...FE word.
Currently i am using 644.53125MHz frequency input to xcvr refence input. Previously i used to use 322.265625MHz. Actually there is no difference.
I will let you know my simulation results. Thanks a lot for your helps.
