How to clock the Cyclone 10GX Transceiver Channel for 10GBASE-R
As I understand it, you have some inquiries related to the clocking for the C10GX 10GBaseR. For your information, you should connect the tx_coreclkin with XGMII clock of 156.25MHz. I believe there might be some typo in the user guide or some of the internal blocks are not shown. Sorry for the inconvenience. However, at the top level, you would need to 156.25MHz to tx_coreclkin.
To further validate your design, it is recommended for you to create a simple test design and run through simulation to check for basic functionality before you add in more module.
In my whole system, the receiver's phy-layer is a TI's TLK10031 which is a 10BASE-KR chip. My transmitter is a Cyclone 10 10BASE-R transceiver. Do you think it is workable together?
I found the receiving data with missing 64-bit words frequently at receiver's XGMII bus monitored by SignalTap.
Looking forward to your help.
