SrLam9
8 years agoHow does the Remote Update IP work?
Hi am trying to implement the Remote update IP core into my Arria 10 system with an EPCQ512. I want to have an application and factory configuration to fall back on. I am configuring the Remote updat...
Nooraini_Y_Intel
7 years agoHi SrLam9,
The reset input port does need to be set to 0. Since this is an active high signal, asserting this signal high will reset the RSU IP core. From the Signal Tap screen shot it does not show what is the data parameter that you are trying to set.
Can you provide some screen shots of the Signal Tap showing each parameter being set/write (AnF bit, watchdog timer, application boot address) before triggering the reconfig port for use to check the steps? Did you strobe/set the reconfig input to high at least for 250ns? This is the minimum require to set reconfiguration input of the RSU IP core high in order to start the reconfiguration.
Nooraini
