SrLam9
8 years agoHow does the Remote Update IP work?
Hi am trying to implement the Remote update IP core into my Arria 10 system with an EPCQ512. I want to have an application and factory configuration to fall back on. I am configuring the Remote updat...
SrLam9
7 years agoHi,
After checking my Verilog, I found that the my reset generator for the WDT was not generating a signal.
However, I still cannot load the application configuration. After tracing with signaltap, I found that the data out when reading the Reconfiguration Trigger conditions register is 0x1F. Is this an erroneous value or is it possible for all of these reconfiguration triggers to occur simultaneously? (I did not toggle nConfig). Is this a cause of trying to use SignalTap with an .sof and remote update IP?
Thank you
