How does the Remote Update IP work?
Hi SrLam9,
Have you actually try the example design which is proven to be working with 2 images (1 factory and 1 application image)? Try to do this to understand RSU correct behaviour before try to perform the fall back testing (empty application image). This is to ensure that you are able to perform AS configuration successful.
To be honest, your statement here in the original thread is confusing:
"However, when I convert .sof into a .jic and load it into the EPCQ, it never boots."
Since you mentioned it never boots, this only tell me the AS configuration does not work. As mentioned before, did you actually check the nCONFIG, nSTATUS and CONF_DONE signal after power up? Have you try to only perform normal AS mode without using RSU IP in the design? Just use a simple project design without RSU IP and test the AS configuration to see if your design can be program into the Arria 10 device or not.
Thank you.
Nooraini
