SrLam9
8 years agoHow does the Remote Update IP work?
Hi am trying to implement the Remote update IP core into my Arria 10 system with an EPCQ512. I want to have an application and factory configuration to fall back on. I am configuring the Remote updat...
Nooraini_Y_Intel
8 years agoHi SrLam9,
Thanks for the update. Did you check the nCONFIG, nSTATUS and CONF_DONE signal after power up? Have you try to only perform normal AS mode without using RSU IP in the design? Just use a simple project design without RSU IP and test the AS configuration from EPCQL512 if your design can be program into the Arria 10 device.
Thank you.
Nooraini
