SrLam9
8 years agoHow does the Remote Update IP work?
Hi am trying to implement the Remote update IP core into my Arria 10 system with an EPCQ512. I want to have an application and factory configuration to fall back on. I am configuring the Remote updat...
Nooraini_Y_Intel
8 years agoHi SrLam9,
Did you set the correct the Arria 10 MSEL pins to Active Serial x1/x4? Did you set the configuration scheme Active Serial x1/x4 int he Quartus project design before compilation? Can you provide screen shot on the steps you did to setup the project design and generating the .sof to .jic file?
There is an existing Arria 10 RSU example from the user guide. Please refer to page 43:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altremote.pdf
Thank you.
Nooraini
