How do I select which hard memory controller to use if my FPGA has two controllers?
Hi KMich2,
The Arria V HMC use dedicated I/O pins as data, address, command, control, clock, and ground pins for the SDRAM interface. I have highlighted the hard memory interface pin-out in YELLOW in attached pin-out excel file. Therefore, user shouldn’t be assigning hard memory interface DDR3 pin-out to other pin location anymore. Only dedicated pin-out is acceptable.
I suggest you to modified your design by removing all the pin location assignment for DDR3 IP and re-compile your project.
Hope this helps.
NAli1
The pin assignments we are using are in accordance to this table, but for the hard memory controller pins shown on IO bank 4, instead of IO bank 7 (which are automatically assigned by the fitter if we do not constrain the pins). As there are two hard memory controller, how do we get the fitter to use the other one, as our memory chip is wired to IO bank 4 and changing our design is not an option for us.
