How do I pick up altera_a10_xcvr_clock_module in a Cyclone 10 GX Modelsim Simulation?
When simulating a Cyclone 10 GX Verilog design in Modelsim, I'm getting the following error when instantiating the design:
** Error: (vsim-3033) Instantiation of 'altera_a10_xcvr_clock_module' failed. The design unit was not found.
All the other IP blocks are found / instantiated.
I'm wondering if I need to install the Arria libraries.
Also, we're using a non-paid license for the Cyclone 10 GX.
Thank you
Thank you for the reply.
I wasn't able to find the library for altera_a10_xcvr_clock_module.
However, since it provides no functionality to a simulation, the simplest path forward was to define it out with our SIMULATION directive.
- CheepinC_altera
As I understand it, you observe some problems with the C10GX Modelsim simulation. To further narrow down the problem, you can do the folloiwng:
1. Look through the Modelsim simulation messages to see if there is any compilation error during any library related to "altera_a10_xcvr_clock_module".
2. If it is due to library file not found during compilation, you can look into the simulation TCL files to check from which specific directory is Modelsim looking for when trying to compile the "altera_a10_xcvr_clock_module". Then you can check if this file is available in your local Quartus installation.
3. If the physical library file can be found, but compilation still prompting error, it might be related to the directory path too long, especially in Windows system. You can try to move your design folder to a shorter path directory.
4. If the physical library file cannot be found in your Quartus installation, we might need to further debug into this. You may need to create a simple test design which could replicate this obervation and share with me.
5. Would you mind to further elaborate on the non-paid license that you are referring to? Is it an evaluation license?
- mindchasers
- CheepinC_altera
Thanks for your update. Glad that you have found the workaround. Thank you.
- CheepinC_altera
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
