BQi
6 years agohow can we get the hdl source code of platform design ip
such as multiplex ip, we can find it in install directory. our end customer would not like to use qsys or platform designner how can we get these ipcores source code?
SyafieqS
6 years agoHi Chuang,
If you want the HDL, you can generate HDL code for IP according you what is desired. Once finished you can start from there, I am not sure if there is other alternative than generating HDL file for IP method.
- BQi6 years ago
If the ipcore in platform designer, before you finish building up the system and generate the system, how can you get the hdl code? I do know if we finish the whole system, we generate the system, we can get the hdl code, but it is too late for us to get the code at that time.
