DdeBr
6 years agoHow can I configure the chip select high time (time between flash operations) when using the Generic Serial Flash Interface IP
We are clocking the Generic Serial Flash Interface IP at 156.25 MHz on a Cyclone-10GX, with a clock divider of 4. We can configure the chip select delay before the first clock, and after the last clo...
JohnT_Altera
6 years agoHi,
Are you saying, that everything work fine with the below setting? If yes, then can you use the setting to move forward?
@1: 0x00010
@2: 0x00088
@3: 0x00000
@4: 0x00000
@5: 0x00403
@6: 0x00502
JohnT_Altera
6 years agoHi,
May I know if this setting help on your issue?
