DdeBr
6 years agoHow can I configure the chip select high time (time between flash operations) when using the Generic Serial Flash Interface IP
We are clocking the Generic Serial Flash Interface IP at 156.25 MHz on a Cyclone-10GX, with a clock divider of 4. We can configure the chip select delay before the first clock, and after the last clo...
nlete
6 years agoHi John,
I tried with your settings, and it does not work. (error in read values, write operations not working)
With your settings, the chip select high time is 30ns and does not respect the EPCQ256 datasheet (50 ns min).
I think it is only a question of chip select high time. I increased the time between two commands sent to the IP in order to increase the CS high time, and it works for all commands (sector erase, chip erase...).
