HBhat2
Contributor
7 years agoHigh Speed Reed-Solomon Modelsim simulation
I created a Simple project with High Speed RS-FEC encoder and decoder and generated the Test bench systems. After generating the files, I opened Modelsim (both quartus and Modelsim version is 18.1) and ran "source msim_setup.tcl"
I observed that none of the files got compiled and work library shows empty. I captured the log and attached for the reference. Please suggest me how to proceed with the simulation.
With Regards,
HPB
- CheepinC_altera
Hi HPB, As I understand it, you seems to have some inquiries related to the Modelsim simulation with the HSRS IPs. Just would like to check with you, after you ran "source msim_setup.tcl", did you have had a chance to type "ld" command in the Modelsim to start the library compilation and elaboration? Please let me know if after running "ld", there is still no compilation running. Thank you.- HBhat2
Contributor
Hi @cheepinc_Intel ,
You are right. It is my mistake. After Ld command, the simulation is launched. Thank you for your support.
With regards,
HPB
- CheepinC_altera
Hi HPB, Thanks for the update. Glad to hear that you are able to run the simulation now. Thank you.
