High-Speed Reed-Solomon IP Core
As per my discussion with peers, the following are our understanding for your reference:
1) out_decfail - When this signal will be set. How to reset this failure?
[CP] This signal will be asserted when the errors within a packet exceed the decoder's correction capability. This signal should assert together with EOP and de-assert for a new packet.
2)out_errors_out- This include the corrected errors or even uncorrected errors if more bit errors in the received data
[CP] This shows the number of corrected errors. When the out_decfail is asserted, this output may be no longer valid.
3)out_errorvalues_out- What is the value of this set of signals?
[CP] This bus shows the raw symbol with error. The corrected symbol or decoded symbol will be at out_symbols_out.
It is recommended for you to perform a Modelsim simulation to further verify the IP behavior based on your target implementation.
Chee Pin
Hi @cheepinc_Intel ,
Thank you for detailed description. I was looking for the similar description in the user guide.
Yes, I am running the simulation using Modelsim. I enabled the above set of options in the decoder. As I am initially working with Encoder to decoder loopback, I was inserting some errors and checking. But, unable to understand the meaning of above status bits. Now I will decode these status bits as per description provided by you.
With regards,
HPB
- CheepinC_altera7 years ago
Hi, Thanks for your update. Sorry for the confusion with the user guide. Please feel free to share with me your finding if you observe any anomaly with my description vs your simulation. Thank you. Best regards, Chee Pin - HBhat27 years ago
Contributor
There is one more option called "Hyper-Optimization". What role does this option play for the RS FEC Decoder IP? Even, there is no description for "Hyper-Optimization" field in the user guide. How the low, medium, high settings effect the functionality ?
With Regards,
HPB
