HBhat2
Contributor
7 years agoHigh-Speed Reed-Solomon IP Core polynomial
Hi I am planning to use Intel's High-Speed Reed-Solomon IP Core for my requirement with RS-FEC (198,194) with below polynomials. " An RS(198,194) code over GF(28) is used: The primitive polynomia...
- 7 years agoHi HPB, As I understand it, you have some inquiries related to configuring the high speed reed solomon IP to have GF(2^8) with primitive polynomial of p(x) = X^8 + X^4 + X^3 + X^2 + 1. For your information, this p(x) would be corresponding to decimal number of 285. In other words, at the Field polynomial drop down in the IP, you may select "285". Please let me know if there is any concern. Thank you. Best regards, Chee Pin
CheepinC_altera
7 years agoHi HPB,
Chee Pin
HBhat2
Contributor
7 years agoHi Chee Pin,
Thank you for the reply. I was unaware of the representation of polynomials in decimal or hexadecimal number. I gone through the corresponding material and now understood.
With Regards,
HPB
