HBhat2
Contributor
7 years agoHigh-Speed Reed-Solomon Intel FPGA IP - Encoder Latency
Hi, I am using High-Speed Reed-Solomon Intel FPGA IP for (198,194 ) block size and polynomial of 285h. In simulation I see that there is a latency of 10 cycles from first input data valid to first...
CheepinC_altera
7 years agoHi HPB,
As I understand it, you would like to inquire if there is a way to reduce the encoder latency for your specific configuration. For your information, as I look through the user guide, it seems like there is no specific option for user to configure the latency for the encoder. If I understand it correctly, the latency would be dependent on your specific configuration. Sorry for the inconvenience.
Chee Pin
