mmanu6
7 years agohi friends i would like to know if there is tri speed ipcore how to configure with PHY Adress,and adress packets ,can you please share your experiences as soon as possible ,main thought is how to instantiate tri ip ???
Deshi_Intel
7 years agoHi,
May I know are your referring to Ethernet 10M/100M/1G IP when you mentioned "tri speed IP core" ?
If yes, then there are couple of reference design that show case the usage of "Intel FPGA triple speed Ethernet IP".
However, triple speed Ethernet IP is typically tied to FPGA product family. So the next question will be what is the Intel FPGA product that you plan to use with triple speed Ethernet IP ?
For instance, if you want to use triple speed Ethernet IP with Intel Arria 10 FPGA, then you can just search for "Intel Arria 10 triple speed ethernet reference design" in google then it will bring you to the right website.
Let me know if you are having trouble to find the reference design once you identify the desired Intel FPGA product family.
dlim
mmanu6
7 years agoHello dlim,
am doing project on cyclone v E base board ,how to set ip address to PHY and how to configure ip core ,10/100 mbps small mac,i got stuck so can you please let me know if you know.
Thanking you dlim for your time.
