17 years agoHelp with altera FFT
hello; what i want to do is to get spectrum of an sinusoidal signal using the altera fft core i have generated a v8 fft with the following setting: fft point : 64 (to start with) archi...
17 years agoTry make changes gradually, too many changes will not help you. So put back your design streaming as original then input from LUT instead of ADC.
your equation below is not right for its purpose: ROM_data = sin(2*1000*pi*[0:255]/256) plot(ROM_data) and see. It should be like this: ROM_data = sin(2*pi*[0:255]/256); then scale up: data = round(ROM_data * (2^15-1)); %for 16 bit signed Use plot(data) to check result before you go to hardware. The frequency you get from this sinusoid = Fs/256 so if your sampling clk = 50MHz then you should get a line at 50/256MHz since each cycle takes that many clks to finish.If you want other higher frequencies then you can jump the LUT regularly.
