JLee25
Contributor
6 years agoHDMI Long Lock Time
Hi, I am facing the Rx long lock time issue on HDMI 2.0 resolution. I am using Cyclone 10 GX + Quartus 19.2. Do you know how to reduce it? Thank you! BRs, Johnson
Deshi_Intel
6 years agoHi Johnson,
Ok, thanks for providing more info but let's not mix up the 2 issues here.
- Regarding UHD is not working issue
- There are a lot of factor that may impact the functionality like Quartus design timing closure, board signal_integrity, transceiver link tuning and etc
- You need to slowly isolate the issue first
- Regarding HDMI slow lock time issue
- For this, I have clarified with Intel Engineering team. I get a better understanding now and sorry for the confusing design limitation write up in the HDMI design example doc
- What the attached design example statement screen shot means is
- using HDMI IP only, it won’t achieve fast lock time
- As a workaround, user can follow HDMI design example to use the symbol_aligner.v design to improve the lock time.
dlim
